Polar V650 wil niet syncen met Polar Flow op Windows
mcboogaard
Mijn mountainbike: Merida Big Nine 500
za 3 augustus 2019, 22:24
Wil graag morgen een mountainbike route rijden en heb daarom de route geupload in Polar Flow en wil nu syncen met mijn Polar V650.
Echter maakt mijn Polar v650 wel verbinding met Flow, maar zegt dan even wachten, om vervolgens aan te geven dat het mislukt. Geprobeerd op meerdere computers, met meerdere USB kabels en de meest recente software.
Wie weet wat er aan de hand is? Ligt het probleem bij mij, liggen de services van Polar eruit? Hoor het graag.
Mijn log zegt dit:
Application started at: 03.08.2019 21:49:25
Qt version: 5.5.1
OS version: Windows 10
Logfile path: C:/Users/Marco Boogaard/polar/logs/
[21:49:25.153] [13064] Application version: 3.0.0.1337
[21:49:25.161] [13064] Application version: 3.0.0.1337
[21:49:25.161] [13064] Build: Distribution
[21:49:25.162] [13064] Libpolar2 version: 7.4.0
[21:49:25.162] [13064] Set no proxy.
[21:49:25.162] [13064] Set application proxy: and port: 0
[21:49:25.162] [13064] Lang code: nl
[21:49:25.162] [13064] Language file found: :/resources/tr/translations_nl.json, code: nl
[21:49:25.205] [13064] *** Second time use detected ***
[21:49:33.144] [13064] Application version: 3.0.0.1337
[21:49:33.145] [13064] Application version: 3.0.0.1337
[21:49:33.145] [13064] Build: Distribution
[21:49:33.146] [13064] Libpolar2 version: 7.4.0
[21:49:33.492] [13064] QtWebKit version: 538.1
[21:49:33.733] [13064] status: 1, elapsed: 185, networkAccessible: 0
[21:49:33.737] [13064] Set no proxy.
[21:49:33.737] [13064] Set application proxy: and port: 0
[21:49:33.737] [13064] Start loading dialog...
[21:49:33.796] [13064] With proxy: :0/ui/index.html
[21:49:33.799] [13064] progress: 10
[21:49:35.330] [13064] progress: 50
[21:49:35.437] [13064] progress: 50
[21:49:35.480] [13064] progress: 53
[21:49:35.607] [13064] progress: 55
[21:49:35.617] [13064] progress: 57
[21:49:35.622] [13064] progress: 59
[21:49:35.659] [13064] progress: 61
[21:49:35.701] [13064] progress: 63
[21:49:35.724] [13064] progress: 65
[21:49:35.758] [13064] progress: 67
[21:49:35.785] [13064] progress: 69
[21:49:35.814] [13064] progress: 72
[21:49:35.833] [13064] progress: 74
[21:49:35.866] [13064] progress: 76
[21:49:35.883] [13064] progress: 78
[21:49:35.924] [13064] progress: 80
[21:49:35.973] [13064] progress: 82
[21:49:35.985] [13064] progress: 84
[21:49:36.068] [13064] progress: 86
[21:49:36.195] [13064] progress: 87
[21:49:36.297] [13064] progress: 88
[21:49:36.414] [13064] progress: 88
[21:49:36.516] [13064] progress: 89
[21:49:36.630] [13064] progress: 90
[21:49:36.915] [13064] progress: 90
[21:49:37.065] [13064] progress: 90
[21:49:37.166] [13064] progress: 90
[21:49:37.270] [13064] progress: 90
[21:49:37.375] [13064] progress: 90
[21:49:37.480] [13064] progress: 90
[21:49:37.627] [13064] progress: 90
[21:49:37.733] [13064] progress: 90
[21:49:37.842] [13064] progress: 90
[21:49:37.947] [13064] progress: 90
[21:49:38.051] [13064] progress: 90
[21:49:38.152] [13064] progress: 90
[21:49:38.261] [13064] progress: 90
[21:49:38.364] [13064] progress: 90
[21:49:38.471] [13064] progress: 90
[21:49:38.617] [13064] progress: 90
[21:49:38.723] [13064] progress: 90
[21:49:38.871] [13064] progress: 90
[21:49:38.949] [13064] win192
[21:49:38.960] [13064] Common: contentServerVersion: 2.53.0
[21:49:38.960] [13064] Start... Version: 2.53.0
[21:49:38.967] [13064] Remote.Read, url: /tr/translations_nl.json
[21:49:39.041] [13064] progress: 90
[21:49:39.055] [13064] ReadReady, status: success, callerName: SyncMain
[21:49:39.056] [13064] data.length: undefined
[21:49:39.056] [13064] status: 200, OK
[21:49:39.057] [13064] translationLoad: success
[21:49:39.059] [13064] status: 200
[21:49:39.129] [13064] Remote.Read, url: /ui/devicelist.html
[21:49:39.142] [13064] progress: 90
[21:49:39.201] [13064] ReadReady, status: success, callerName: SyncMain
[21:49:39.202] [13064] status: 200, OK
[21:49:39.212] [13064] Model: generic
[21:49:39.321] [13064] progress: 90
[21:49:39.423] [13064] progress: 90
[21:49:39.425] [13064] progress: 100
[21:49:39.426] [13064] status: 1
[21:49:46.864] [13064] Bonjour version: 2.0.4.0
[21:49:46.864] [13064] Start loading dialog...
[21:49:46.870] [13064] With proxy: :0/ui/index.html
[21:49:46.871] [13064] progress: 10
[21:49:46.959] [13064] progress: 50
[21:49:47.027] [13064] progress: 52
[21:49:47.054] [13064] progress: 54
[21:49:47.098] [13064] progress: 56
[21:49:47.102] [13064] progress: 59
[21:49:47.151] [13064] progress: 61
[21:49:47.156] [13064] progress: 63
[21:49:47.198] [13064] progress: 65
[21:49:47.209] [13064] progress: 67
[21:49:47.250] [13064] progress: 69
[21:49:47.269] [13064] progress: 71
[21:49:47.307] [13064] progress: 74
[21:49:47.322] [13064] progress: 76
[21:49:47.350] [13064] progress: 78
[21:49:47.376] [13064] progress: 80
[21:49:47.421] [13064] progress: 82
[21:49:47.450] [13064] progress: 84
[21:49:47.565] [13064] progress: 86
[21:49:47.665] [13064] progress: 87
[21:49:47.789] [13064] progress: 88
[21:49:47.894] [13064] progress: 89
[21:49:48.021] [13064] progress: 89
[21:49:48.125] [13064] progress: 90
[21:49:48.396] [13064] progress: 90
[21:49:48.541] [13064] progress: 90
[21:49:48.641] [13064] progress: 90
[21:49:48.745] [13064] progress: 90
[21:49:48.847] [13064] progress: 90
[21:49:48.950] [13064] progress: 90
[21:49:49.089] [13064] progress: 90
[21:49:49.189] [13064] progress: 90
[21:49:49.296] [13064] progress: 90
[21:49:49.396] [13064] progress: 90
[21:49:49.502] [13064] progress: 90
[21:49:49.603] [13064] progress: 90
[21:49:49.710] [13064] progress: 90
[21:49:49.829] [13064] progress: 90
[21:49:49.930] [13064] progress: 90
[21:49:50.084] [13064] progress: 90
[21:49:50.232] [13064] progress: 90
[21:49:50.333] [13064] progress: 90
[21:49:50.346] [13064] win192
[21:49:50.350] [13064] Common: contentServerVersion: 2.53.0
[21:49:50.350] [13064] Start... Version: 2.53.0
[21:49:50.350] [13064] Remote.Read, url: /tr/translations_nl.json
[21:49:50.409] [13064] ReadReady, status: success, callerName: SyncMain
[21:49:50.409] [13064] data.length: undefined
[21:49:50.409] [13064] status: 200, OK
[21:49:50.409] [13064] translationLoad: success
[21:49:50.422] [13064] Remote.Read, url: /ui/devicelist.html
[21:49:50.464] [13064] progress: 90
[21:49:50.515] [13064] ReadReady, status: success, callerName: SyncMain
[21:49:50.515] [13064] status: 200, OK
[21:49:50.533] [13064] Model: generic
[21:49:50.570] [13064] progress: 90
[21:49:50.679] [13064] progress: 90
[21:49:50.740] [13064] progress: 100
[21:49:50.741] [13064] status: 1
[21:50:50.546] [13064] ErrorCase: undefined, undefined
[22:21:06.748] [13064] Bonjour version: 2.0.4.0
[22:21:06.749] [13064] Start loading dialog...
[22:21:06.753] [13064] With proxy: :0/ui/index.html
[22:21:06.753] [13064] progress: 10
[22:21:07.079] [13064] progress: 50
[22:21:07.179] [13064] progress: 50
[22:21:07.292] [13064] progress: 50
[22:21:07.392] [13064] progress: 50
[22:21:07.497] [13064] progress: 50
[22:21:07.598] [13064] progress: 50
[22:21:07.706] [13064] progress: 50
[22:21:07.808] [13064] progress: 50
[22:21:07.908] [13064] progress: 50
[22:21:08.011] [13064] progress: 50
[22:21:08.143] [13064] progress: 50
[22:21:08.253] [13064] progress: 50
[22:21:08.355] [13064] progress: 50
[22:21:08.404] [13064] progress: 54
[22:21:08.405] [13064] progress: 58
[22:21:08.409] [13064] progress: 62
[22:21:08.410] [13064] progress: 64
[22:21:08.414] [13064] progress: 68
[22:21:08.456] [13064] progress: 72
[22:21:08.460] [13064] progress: 76
[22:21:08.461] [13064] progress: 80
[22:21:08.461] [13064] progress: 82
[22:21:08.820] [13064] progress: 82
[22:21:08.870] [13064] progress: 85
[22:21:08.982] [13064] progress: 87
[22:21:09.122] [13064] progress: 88
[22:21:09.225] [13064] progress: 90
[22:21:09.331] [13064] progress: 90
[22:21:09.450] [13064] progress: 90
[22:21:09.553] [13064] progress: 90
[22:21:09.652] [13064] progress: 90
[22:21:09.761] [13064] progress: 90
[22:21:09.912] [13064] progress: 90
[22:21:10.017] [13064] progress: 90
[22:21:10.123] [13064] progress: 90
[22:21:10.232] [13064] progress: 90
[22:21:10.343] [13064] progress: 90
[22:21:10.445] [13064] progress: 90
[22:21:10.596] [13064] progress: 90
[22:21:10.707] [13064] progress: 90
[22:21:10.807] [13064] progress: 90
[22:21:10.882] [13064] win192
[22:21:10.886] [13064] Common: contentServerVersion: 2.53.0
[22:21:10.886] [13064] Start... Version: 2.53.0
[22:21:10.892] [13064] Remote.Read, url: /tr/translations_nl.json
[22:21:10.947] [13064] progress: 90
[22:21:10.955] [13064] ReadReady, status: success, callerName: SyncMain
[22:21:10.956] [13064] data.length: undefined
[22:21:10.956] [13064] status: 200, OK
[22:21:10.956] [13064] translationLoad: success
[22:21:10.980] [13064] Remote.Read, url: /ui/devicelist.html
[22:21:11.067] [13064] progress: 90
[22:21:11.068] [13064] ReadReady, status: success, callerName: SyncMain
[22:21:11.069] [13064] status: 200, OK
[22:21:11.072] [13064] Model: generic
[22:21:11.178] [13064] progress: 90
[22:21:11.295] [13064] progress: 90
[22:21:11.329] [13064] progress: 100
[22:21:11.329] [13064] status: 1
[22:22:11.108] [13064] ErrorCase: undefined, undefined
Altijd leuk mountainbiken :-q
zo 4 augustus 2019, 00:24
1e fout treed op net voor het gebruik vd bonjour service.
Polar maakt gebruik vd bonjour service van apple. Er was na een update van bonjour een probleem ontstaan voor polar.
Dat is opgelost in de laatste versie vd polar software.
Zal wel te googlen zijn, was ook een topic hierover op het forum.
Is jouw polar en jouw pc helemaal up to date?
Probeer de v650 en de polar software te updaten.
zo 4 augustus 2019, 00:31
Dit topic. Wellicht staat er bruikbare informatie in.
mcboogaard
ma 5 augustus 2019, 09:52
heb alles maar weer opnieuw geinstalleerd en toen werkte het. Ben volgens mij up to date, maar zal onderwater dan toch nog wel wat geupdate worden.
Hopelijk hoef ik nu niet elke keer voor gebruik te deinstalleren en installeren...
Dank voor de hulp.
ma 5 augustus 2019, 11:21
Waarschijnlijk de Bonjour wat TSTM zegt.
Hier ook een keertje gehad maar afgelopen jaar geen problemen meer met de V650 en koppelen aan Windows.
